Re: Mowin B
Dale(MS)
04-20-2003 08:26:36
Terry, I use a "B" with a L-59 Woods belly mower with caster wheels. For some reason I now enjoy mowing the yard. Woods had all the right hardware to go with the unit and easy instructions to help set it up. Seems like I had to move one rear tire out some.I don't have a 3-point lift cause thats all I do with this tractor.Dale
Eric
04-23-2003 20:41:11
 Re: Re: Mowin B in reply to Dale(MS), 04-20-2003 08:26:36
I too have a L59 mower on my "B". I just changed blades and am having quite a time getting the belt back on correctly. It seems like the belt is too short. The two adjustment pulleys near the PTO pulley are all the way at the top and I have to really pull to get the belt on. There's no need to adjust the pulleys because it's tight as soon as I get the belt on. Is thishow yours works?
Thanks,
Eric
rudy
04-24-2003 17:58:22
 Re: Re: Re: Mowin B in reply to Eric, 04-23-2003 20:41:11
eric the 2 arms that come rearward off of your mower deck with all of the holes in them need to be moved back 1 or 2 holes this will give u more adjustment at the 2 idler pulleys
