Re: WD stuck in forth gear
Author |
wdTom
04-17-2003 17:41:09
I would suggest taking off the shifter cover and seeing if all the shift forks are in good condition, not worn or broken. If you lined up the rails the shifter goes into and it is in gear still, it is in two gears at once, it is in a gear and the shifter fork isn't in it's proper place in the gear, that is the gear is not being moved properly by the fork, or some other such thing. It shouldn't be able to go into two gears at once, there is linkage in the shift rails in the cover to prevent this. This could be worn. It is a small pin, as I remember, that slides back and forth between all the 3 rails. If you have to take the rails out of the cover watch out for springs, pins, and balls. If the forks and such in the cover is all in order put the gears in neutral and put the cover back on, carefully, to make sure the forks all go where they should in the gears. You could drain the oil to see beter the condition of things and to make it easier to see a little when putting the cover back in position. All this isn't all that hard, might help, if you have to take it apart, if you have the repair manual. The AC ones or reprints of AC are the best. Keep us up to date on what you find.
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
John Deere 143 Loader, good condition.
[More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
