Re: Allis Wd wiring mess
steve
04-16-2003 14:55:19
i put a voltage regulator on my B with a 12 volt negative ground generator. I will send yuou a diagram. You need to know you have a positive or negative ground regulator (and system) Basically the "F" on the generator goes to the "F" on the regulator. THe "A" on the generator goes to the "G" on the regulator. The B on the regulator goes to the battery "hot" terminal, which ever is not grounded. Then you touch a jumper from B to G terminals to polarize the system, then startup the motor and chekc charge. Do not connect any wire from the generator to the light switch. If you need more help, send me a note.
