Re: WD timing
Duey (IA)
04-13-2003 21:52:07
Jim,
Dave got it right. The low voltage current goes through the coil and then to ground when the points close. This surge of current aided by the condensor causes the HIGH voltage from the coil to the plugs. Static (not running)timing just gets everything lined up so the spark is produced and can travel from the coil to the correct plug at the correct time. The spark at the points says the low voltage circuit is working. If the coil is putting out a good HIGH voltage spark, then then the only thing is to get it to the right plug at the right time. When #1 piston is at Top Dead Center, the rotor has to be pointing to a tower on the dist cap that has #1 plug wire in. In this position the dist clamp bolt can be loosened and with the switch on turn the dist to open the points and then close the points. When you see the spark between the contacts, tighten the clamp bolt. Then clockwise install the rest of the plug wires 2 4 3. The ignition should now be static timed. As Dave said lay a plug on metal and you should get spark If no spark it has to be one of the following; coil, condensor, rotor, cap, wire, or plug. If you replace the coil get one with a internal ballast resister. Duey
