Re: wd misses when hot
Farmer in the D
04-13-2003 19:58:32
One other thing since you mentioned it changes when you pulled the air cleaner. I have seen on earlier posts that the weight of the oil in your air cleaner will affect the running. If it is too heavy, air cannot move through it readily and might choke itself out. Last year I only had 10W30 around and cleaned my bowl out and refilled it with that to get some mowing done. Come to think of it, it is still in there. If it is happening often you would think your plugs were carboning dry chalk black. Check for carbon tracking on the porcelain. If it is there you may need new boots too. I would pull some plugs and get a look at those too. Between the fuel drier and a set of plugs, you'll spend $10 and I have been amazed as to how much just changing plugs will change the operation.
