Re: 180 Diesel hard to Start
Kevin H
04-12-2003 06:47:10
Hi! If the engine and pump and injectors have not been overhauled since new, then it could be time. With properly serviced injectors and pump, you should be able to start it. Is the compression in the engine good?? If not, then that could be a contributing factor as well. With the injectors, they could be slobbering rather than spraying after all these years. Have the pump and injectors done, and at the same time, have a compression check done on the motor. AC's are known to be somewhat hard starters, however with the right ingredients, they are not all that bad.
