Re: oil pump rebuild
dave
04-07-2003 21:41:26
Spin the shaft while under some oil, you should be able to see if it is pumping, then use another thumb (from your wifes hand) try to stop the flow. Good luck Dave
CHALMERSBOB
04-08-2003 17:10:02
 Re: Re: oil pump rebuild in reply to dave, 04-07-2003 21:41:26
DID THE TRACTOR SIT VERY LONG BEFORE YOU TORE THE MOTOR DOWN? 1-2 YEARS? SOMETIMES THE PUMP WILL NEED TO BE PRIMED AFTER SITTING FOR A WHILE
BOB
