Re: Wiring my wd45
Duey (IA)
04-04-2003 18:55:10
You can hook it to the same post as the coil wire IF you install either a warning light or a diode in the alternator wire. This stops a backfeed from the alternator that keeps the engine running after the key is off. The automotive switch with acc. does the same thing by seperating the coil wire from the alternator wire. Duey
