Re: B motor question..
Phil Maurer
03-28-2003 16:34:26
Pull it apart and then mike everything up..And go from there. Sleeves are available with complete crank and cam shaft rebuilds on the net.I rebuilt a 39 B from the bottom up. Ihave never seen a motor so worn out! The oil pump drive pin on the cam shaft just wore off... Guess what happened to the motor. If you are serious about restoration criuse the net and find parts new and used. Have fun
