Re: WD45 carb n plugs
Steve in N.J.
03-25-2003 14:57:24
Dave, Autolite 295's for mag, or 303's for distributor seem to be the two magic numbers that the folks been using. They work nice! I'm trying a set of NGK's in my B. They seem to work good so far also. NGK # is B6S. Autolites are the choice though.. Not sure on the carb for WD, but I know M/S carbs came on a lot of different model AC's.... Hope this helps.
Steve/B&B Custom Circuits
Brian G. NY
03-26-2003 05:50:10
 Re: Re: WD45 carb n plugs in reply to Steve in N.J., 03-25-2003 14:57:24
There were several different model carbs used on the WD-45s but the TSX-464 seems to be the most common. I have 2 WD-45s with the TSX-464 & another (1956) with a TSX-471.
dave wi
03-26-2003 16:11:01
 Re: Re: Re: WD45 carb n plugs in reply to Brian G. NY, 03-26-2003 05:50:10
thanks Brian,this a peice together tractor wasnt to sure about the carb
Dave Wi.
03-25-2003 15:15:28
thanks Steve
David Maddux
03-26-2003 04:25:42
 Re: Re: Re: WD45 carb n plugs in reply to Dave Wi., 03-25-2003 15:15:28
I am having good luck with AC 45's. I put them in all of my allis's.
