Re: oil bath air cleaner
DAVID C.
03-20-2003 06:53:00
Good question. I am curious about that too. I just recently serviced mine and re-filled the whole reservoir to ring indicated on outside of cup. Now when I stop the engine off oil leaks out of the cup and I'm wondering if I've made a mistake and if so how it should be filled.....
Any help out there?
Bryan Smith
03-20-2003 13:36:18
 Re: Re: oil bath air cleaner in reply to DAVID C., 03-20-2003 06:53:00
Usually you fill both inner and outer "rings" as you call them, up to the top of the inner ring wall. On the AC's I have tah is usually filling them up to a kind of lip or ring pressed in the cup outer wall. I don't remember where that is on my WD 45, but on the B / C / CA it's very obvious. On them I think the level is approximately 1/2 inch down from the top lip of the cup (maybe a little more or a little less). Hope that helps.
