Re: Sixteen year old need's help on AC-B
John in NC
03-17-2003 06:33:51
Nice web site. Good looking B also. I had the oil filter problem once myself and found that the small tube that goes up through the center of the filter was clogged with a small amount of rust. It has very small holes in it and this could easily happen especially if it ever sat for a period of time. The small tube can be pulled out of the housing with a pair of pliers and easily be cleaned out. If there is truly no oil pressure it should be noted by the oil pressure gauge and also a knocking sound within the engine would be heard which would not be a good condition to have. Also make sure the oil lines to the filter housing are not clogged. Mine was running fine even though there was no oil going through the filter until I unclogged the tube. Good luck....John ...PS I used to live in Andover, Maine and my mom still lives there.....Long winters.....
