Re: New zenith carb running wide open
Author |
Duey (IA)
03-15-2003 20:22:37
Sounds like your governor spring unhooked when you were workin on it. Duey
Aaron
03-15-2003 20:38:28
Re: Re: New zenith carb running wide open in reply to Duey (IA), 03-15-2003 20:22:37
Governor spring is Ok. Moved governor link to carb by hand to the idle position on tractor, still races. It's a carb problem because I put old one on and the tractor idles fine. Also tried new carb out on my C and it does the same thing. Something isn't closing on carb. Could needle be stuck or something else not assembled correctly?
Little Ed
03-16-2003 04:26:17
Re: Re: Re: New zenith carb running wide open in reply to Aaron, 03-15-2003 20:38:28
Don't think it could be a needle in the carb, in order to run away like that the throttle butterfly has to be opening to let more air in. Sounds like the governor is pulling the throttle open. check to make sure the lever that connects to the throttle is not installed upside down. Found that on a stationary engine a few months ago. Also found one that had the choke rod hooked to the throttle, although it wasn't on an Allis. Might check though.
Brian G. NY
03-16-2003 06:55:02
Re: Re: Re: Re: New zenith carb running wide open in reply to Little Ed, 03-16-2003 04:26:17
Ed, That's the first thing I thought of when I read this; some throttle levers are hooked up differently for different applications. I ran into this last fall when I adapted an old Zenith carb to a Gravely.
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Women and Tractors - More Views From the Farmer's Wife - by Teri Burkholder. The top ten reasons why the judges wouldn't let you participate in the stock antique tractor pull: Hey, this is stock! It came with that V8 in it! That "R" on my tires stands for "really old" not radial! Blue gas? We thought it was a pretty color! What wire hooked to my throttle?
... [Read Article]
Latest Ad:
A pair of 11x38 drop center rims off of an Oliver 77, super nice originals, never had fluid in them, can send pictures,calls only
[More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
