Company Logo (800) 853-2651 Shop Now
Re: Manifold Nuts and Studs
Tom
03-09-2003 18:04:07
A very cool way if you have a milling machine is to drill a hole as close to the center of the stud as you can, run an endmill down that is smaller than the threaded hole, say 1/4" or so, and carefully enlarge the hole with it until you just see the thread all around. It will look like a rust color line spiraling down into the hole. Now with a pick get the top of the "thread" started and pull it out with vice grips. Did this with several of mine. Made stainless studs to replace all of them too, and stainless nuts.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 14 80# Massey front weights [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
