Re: WC or WD
Farmall Daddy
03-09-2003 11:18:34
A WD will have a snap coupler, hydrolics, traction booster, and a standard pto. WC's don't have hydro's, or snap coupler. WC's pto is up under the motor and requires a stub shaft to connect it to the back. They have the same motor but different rpm's and power. On a WC, the serial number will be on the rear end on the transfer case {what I call it}, that is just below the seat on the styled WC's. Find your serial number and post it so I could look it up for you. Good Luck!!
tbear
03-10-2003 19:58:32
 Re: Re: WC or WD in reply to Farmall Daddy, 03-09-2003 11:18:34
Hello I'm sure i have 3 wc but one i can't find the ser number for i'll check near the brake lever tomorrow all have the hand brakes,the long shift under the tank.None of them have the hand clutch or foot brakes the first ser is iron wheels no engine ser wc 661xx the next is tempearly a parts tractor that i plan on fixing ser is wc 1071xx the 3rd my work tractor i have rearend off and am using the parts rearend temporary i can't find ser number looks more like a ford rearend in shape.I'll check for ser near brake lever tomoorowt thnx for your help tbear
Farmall Daddy
03-23-2003 16:55:38
 Re: Re: Re: WC or WD in reply to tbear, 03-10-2003 19:58:32
661xx= 1938
1071= 1948
dan wc ne wyo
03-11-2003 19:10:15
sounds like your 3rd rear hsing is a steel one instead of cast iron these were used during ww II manufacture. look above the top of the "bowl" on the rear of the diff. hsng. flat surface around the top and rear numbers are 3/8 to 1/2 inch tall may be covered by paint. stamping will face you same as the ones on the square pad. HTH dan ne wyo
