Company Logo Shop Now
Re: WC or WD
Aaron
03-09-2003 06:29:18
WC had hand brakes, no hand clutch, no hydraulics, no lift arms, a completly different throttle setup, the transmission was way under the gas tank with a long shift lever, it had a solid mounted drawbar, not the removable one of the WD, had different sized rear tires, different style rims, the battery (if it even had one) wasmounted on the side of the frame, the WD was right in front of the seat. WC serial number is directly above the PTO on the rear housing, starts wit WCxxx, WD serial number is on the left brake housing stamped into a flat spot on the casting. Starts with WDxxx. Engines were basically the same, with some differences in manifolds and governers.
Aaron
Copyright © 1997-2020 Yesterday's Tractor Co.
