Re: 7060 allis chalmers WON'T START
Aaron
03-08-2003 16:11:17
Are you sure you have the fuel shut off in the cab set right? I forget which is which way is which, but it's backwards of what most run. I almost want to say that pulling it out turn the fuel on, and pushing it in shuts ot off. Might want to find a manual and read.
Aaron
otto
03-09-2003 11:08:54
 Re: Re: 7060 allis chalmers WON'T START in reply to Aaron, 03-08-2003 16:11:17
allis is backwards to everything out there.
John
03-09-2003 05:27:58
The black knob is pulled out for fuel on a 70 series AC. The 80 series used the idle stop like most of the tractors of that era. But the AC goes back to the D series for sure that "back or out" was fuel "on" position until the 80 series, they changed. Also when OHd the dealer(not AC) had the exact same problem that you are experiencing with my 8030. If the injection pump has been pulled and put back on, it can be 180 degrees off on timing. This could be why it has sat for a while, someone did pump work and didn't ever get it to start again. Knowing AC quirks myself is the only reason the dealer got my 8030 to start for them. I was told that they had never heard of such a thing yet I know of a couple of their models that can be timed 180 out too. Good Luck!
