Re: CA not running right
Barry WA
03-03-2003 23:03:45
Dennis, on my C ,with mag. it ended up bein the coil. You probaly should check points, condencer, and valve lash too. one cylinder usally isnt carb problem. first I would swap plug, and wire on # 3, you never know. good luck. Barry
Dennis Short
03-04-2003 20:11:16
 Re: Re: CA not running right in reply to Barry WA, 03-03-2003 23:03:45
Sorry guys I should have told you I rolled the plug, then the wire. Point and rotor and cap look good (although I know this can be deceivin)and also checked valve clearance 3 times. I just thought it was something so easy I was over lookin it ? Sounds like from all the input I should just give her a good tune-up anyway. I will check for Champ plugs tomorrow. Thanks for all the input and I'll let y'all know ?
Barry
03-04-2003 22:40:25
 Re: Re: Re: CA not running right in reply to Dennis Short, 03-04-2003 20:11:16
Dennis, if its an oil problem try autolite # 75 plugs. Thay are workin real good in my C. oil used to coat plugs after a bit of use, with 75's no problem. Was told by old timer at auto parts store, thay were THE plug for well used,gas powered, construction equipment.
