Company Logo Shop Now
Re: AC B engine locked up, HELP!!
steve
03-01-2003 18:52:42
if it really ran out of oil, you are out of luck. if it sat outside and "got stuck", pull the spark plugs and fill it with PB blaster, WD40 , diesel fuel, your choice. Remove the starter and try to bar the motor over with a prybar on the flywheel teeth every day, untill it moves. If you take off the oil pan, remove the center bearing cap covers and examine the bearings to see if it did run out of oil.
Today's Featured Article - ... [Read Article]
Latest Ad: Front hydraulic pump for loader .. drives off tractor front. Mount bracket included. Greisen brand which is my favorite brand for hydraulic controls. This is use some, then removed and stored inside for several years. Can ship send along your zip for rate. thanks [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
Binary file (standard input) matches
