Re: Traction Booster
Dave K
02-28-2003 17:11:57
If it is the same set up as a WD then the answer is no. The traction boost feature is simply a way to transfer some of the weight or load from the snap coupler mounted implement to the rear wheels. It is at it's very best with a snap coupler mounted plow. Again, I am not familiar with the D17.
Dave
Bruce
02-28-2003 21:29:23
 Re: Re: Traction Booster in reply to Dave K, 02-28-2003 17:11:57
Dave you are correct the traction booster was basically set up for the equipment that hooked to the snap coupler. It would like you said transfer the weight to the tractor its best use was with the plow where most of your hard pulling is done.
