Re: My B will not rev up with full throttle
Dale(MS)
02-21-2003 10:43:04
Mike, Might disconnect the throttle linkage in front of the carb at the point where the governor rod comes across in front of the radiator. With the throttle handle on the steering shaft in the wide open position the linkage from the carb to the governor arm should be about 1/16" to short to be able to go back in the hole. If it is not short you have to bend the governor arm so it is short.Check your manual about the 1/16" as that is from memory. Make sure you have the correct governor spring as the wrong tension will give the wrong response. I would get fire to #3 before doing anything. HTH Dale
