Re: My B will not rev up with full throttle
MIKE Update on
02-20-2003 17:57:07
Thanks for the info,
I can grab the carb linkage to overcome the Gov.but it still won,t rev up to full throttle.The bad thing is ,with all the rebuilding on this tractor it has the same problem we started with when we unstuck the motor and started it up ! The only thing not perfect on the tractor is the intake/exhaust manifold, The ear on the far right of the manifold next to the air cleaner is broken, i used a big washer to hold the two pcs together against the head,seals good dosn't seem to leak using the carb cleaner test, also had the manifold presure tested.
