Company Logo (800) 853-2651 Shop Now
Re: My B will not rev up with full throttle
Gordon
02-19-2003 22:05:19
Have you checked to see if the exhaust valve is opening check for bent push riod or rod not in lifter or off. Gordon
mike
02-20-2003 03:34:14
 Re: Re: My B will not rev up with full throttle in reply to Gordon, 02-19-2003 22:05:19
Thanks for the info, but everything mentioned is correct.
Thanks
rudy
02-20-2003 14:59:11
 Re: Re: Re: My B will not rev up with full throttle in reply to mike, 02-20-2003 03:34:14
as for #3 not firing check the simple stuff first spark plug and wire if that is not a problem go a little deeper and pull the valve cover and watch your valve operation to make sure everything is working properly after u have asertained that u are getting fire from the mag or dist.to #3 plug whichever the case might be. as for your problem of not revving up sounds like a governor problem but i have had water in the air cleaner where the oil is supposed to be freeze up and have the same problem u are describing good luck let us know how it works out rudy
Today's Featured Article - The History of Old Abe - by Staff. The Case Eagle - Old Abe - is a well known industrial trade-mark throughout the main streets and countryside's of thousands of cities and hamlets in the United States and civilized countries the world over. King of the air, the eagle is an established symbol in American life and heritage. The Case Eagle Old Abe is far more than merely a trademark. He is a character out of history, a bird with a personality and a story all his own. The story begins in the early spring of 1861. In the wild nor ... [Read Article]
Latest Ad: WANTED Rumely Oil Pull Models W X or M [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
