Re: SOME QUESTIONS ABOUT THE WD45
John Rogers
02-17-2003 19:55:57
Justin you can shift gears with the hand clutch if the transmission oil is warm but its much quieter with the foot clutch. The lock on the foot clutch was used when using the belt pulley, that was the only way to stop it from turning. Traction booster was a system where, when a mounted implement pulled so hard and the hydraulic controls were set properly it would shift some of the weight of the implement to the tractor. To engage the Pto depress the foot clutch and pull up on the rod.Unless you were using a regular AC 3point adapter you wouldn't get any good of the traction booster system.
