Re: seal intake/exhaust manifold
phil johnson
02-16-2003 10:07:11
Sounds like your manifold may be warped or burned and all ports are not at the same level. You may have to remove it and place a good straightedge along the port surfaces where they mate to the head. If there are any gaps you can file it all level or surface grind it so that all port surfaces are flat and even. You can then reassemble it and use hi temp copper silicon if you like, though it shouldn't be necessary.
