Re: Allis C: Lost oil pressure
steve
02-15-2003 12:10:48
behind the oil filter you will see the 1/4 inch pipe coming out of the flywheel housing that supplys oil to valves in teh head, and to the filter housing. take the TEE off this pipe and squirt 10 wt motor oil into it. reinstall and start again, see what happens. yes you can loose prime, normally if the tractor sets for long periods if time, usually a week will not do it.
CHALMERSBOB
02-16-2003 13:10:09
 Re: Re: Allis C: Lost oil pressure in reply to steve, 02-15-2003 12:10:48
REMOVE THE LINE FROM THE TEE TO THE OIL FILTER. TURN IT SO THE FILTER END POINTS UP AND RETIGHTEN TO THE TEE. WITH A PUMP OIL CAN, PUMP OIL INTO THE TUBE TO PRIME THE PUMP AGAIN.
THE SAME THING HAPPENED TO MY C LAST FALL AFTER IT RAN FOR A WHILE AFTER REBUILD. GOOD LUCK, HAVE FUN WITH THOSE ALLIS'
BOB
