Re: Allis B
steve
02-14-2003 18:02:40
take the valve cover and the front gear cover off.
--crank the motor by hand and watch the #1 intake valve open. now the no 1 piston is about at the bottom of the stroke.
--turn the crank shaft 180 degrees. now the crank is about at the top of the stroke on #1piston ready to fire.
--put a straw in the #1 spark plug hole and turn motor slowly and watch straw continue to rise untill it stops (top dead center)
--look thru the 1 inch hole in the left side of the fly wheel housing, you should stop cranking when you see the TDC mark in the hole.
--the timing gears on the front end should now have the alignment marks in alignment.
--take off the distributor or mag cap and the rotor should be pointing at #1 plug wire. if it is not, you need to move the wires on the cap to the right hole, or remove the mag, turn it to the correct position , and reinstall.
--everything is in alignment when #1 (front) is at the top of the stroke.
