Re: coil polarity
DanD.
02-12-2003 12:33:11
It would be best to have the coil hooked up correctly. The "-" terminal on the coil should go to the - terminal of the battery. The + terminal should go to the points because when the points close, it is effectively connected to the + terminal of the battery. All you have to do is reverse the wires. Don't know if it will make a big difference though.
