Re: Saftey w/ snap coupler
Dave K (Fl)
02-09-2003 12:08:22
Have used WD's since the 50's with snap coupler. Never had the hitch come loose. Never heard of this happening till recently when we have more "weekend farmers" using the older equipment. I think if your release chain is too tight or some such it could happen? I have a 1948 WD I plow with now that was converted to the snap coupler in the fifties. I agree with Eldon, I have to back up and release pressure on the "hook" before I can release it. Of course on rough ground the hitch may be alternatly tightening and loosening in the hook. So if your release chain is a bit tight it might release.
Set it up right, should be okay
Dave
Sid
02-09-2003 16:43:46
 Re: Re: Saftey w/ snap coupler in reply to Dave K (Fl), 02-09-2003 12:08:22
Last year the snap coupler let my draw bar loose while pulling a baler. Sure was glad that I was leaving the field and not baling when it happened. Things had worn to the point that there was to much slack everwhere A little welding took care of things though.
