Re: govenor help
Gordon
02-02-2003 20:53:41
Did the gov work all right in the combine? With engine off open throdle handle wide open look at the throdle lever on carb to see if it is wide open.If not Loosen set screw and ajust or slide rod so it pulls harder on the spring. It would be easyer to ajust at idle if you go to far it will not come down to a good idle.
