Re: Model B Main Bearings
Joe
02-02-2003 16:06:37
I rebuilt a AC C last year and had the main and rods cut 020 the book says clearance should be
.001 to .002 .003 maybe a little to much it only holds 20 psi oil pres. so you may loose some pres
make shure the shimes are not hitting the crank
recheck dry!!! this is very tricky duble check
shim thicknes this is the hardest part of this rebuild once this is done clean all parts and coat with STP tork. each one and turn crank shaft
after each one good luck PS mine was .002
and runs great Joe
