Re: WD45 Loading Up
Tom
01-26-2003 10:01:27
Dennis, Is the engine receiving excess fuel - black smoke at high idle and low idle? Adjust the main jet by screwing it in at high idle until it begins to stall and then turn it out 1½ to two turns. Adjust the idle jet so the idle is smooth and there is no black smoke. If you have fuel running out of the carburetor then the needle valve may not be seating, or your float level is adjusted to high. Also, be sure that you have the correct plugs and that they are gapped properly. Keep us posted. Tom
