Re: Removing Crankshaft Fan Drive Pulley on Model C
Dick L
01-13-2003 11:15:26
For the really tough ones, take a piece of 1/4" plate steel and cut a circle from it as large as the pully. Slot the center so it will slide over the inside hub that the setscrew is located. You can then apply more pressure with a puller without breaking the pully. As stated before, you need not worry about bending the pully, it will break very easy. I also use a lot of heat on the hub on the really tough ones.
