Re: Removing Crankshaft Fan Drive Pulley on Model C
rudy
01-12-2003 20:00:36
if u have the locknut loose and the screw backed clear out u should be able to pull it but u might have to get it pretty hot with a torch but be damn careful how much pressure u put on the pully. it is a cast pully and will break pretty easy i would reccomend that u get get some one with some experience to show u how it is done the first time
David Maddux
01-13-2003 04:54:59
 Re: Re: Removing Crankshaft Fan Drive Pulley on Model C in reply to rudy, 01-12-2003 20:00:36
I have had some pretty tough ones too, When I get all the pressure I think the pully will take, I hit the center of the pully with a hammer. Then try to put some more turns on the puller. If it turns easier, turn it til it gets tight again and hit it again, while still bathing it inWD40. It takes a while but has always worked. Dave
