Re: Taking apart rear rims
JMS/MN
01-11-2003 12:19:47
Both of the things you want to do are feasible. I would attempt to move each of the eccentric bolts first, just to make sure they are loose. If they are not, one advantage to taking the cast part loose from the wheel is that then the cast with the tight eccentric could be heated to loosen it. As far as reassembly, it should be no more difficult than rebolting the wheel to the hub. If you're working alone it wouldn't hurt to chain the rim and tire to a hoist, cherrypicker, etc. so it can't fall on you- especially if it has fluid in it.
