Re: WD45 Questions
Farmall Daddy
01-02-2003 15:38:10
I would look for if the motor burns oil or not. This would mean the motor needs to be overhauled. Check the transmission to see if it slips, or if the clutch is bad or not. Check to see if any seals are leaking underneath the front of the motor and in the back where the motor is bolted onto the rear end. If they do leak, this would mean that you would have to dissasemble the entire engine to replace these. These would be the main things I would look for.
