Re: going to look at a CA,,,,,what to look for?
Eldon
12-31-2002 11:43:56
The hand clutch is spring loaded and must be pulled towards the operator to disengage....it operates dry and is a weak link in the CA drivetrain. Many slipped due to improper adjustment or leaking axle seals and were replaced with a solid axle or bolted together. I have 4 CAs and only one has a working hand clutch.
Also check rear rims for rust...they can be expensive. The wide fronts were a little weak and may be bent or welded up....the pivot point on them was a wear point as well. The hydraulic pumps can get sticky and take some time to work, but are easy to work on. Snap coupler hands (if a sc version) can be hard to find if they are missing. Also check for slop in the steering box....good luck!
