Re: Worn shift lever, How do I repair it????
JMS/MN
12-31-2002 11:07:04
Do you really have a WD45? The shifter, with only one groove, sounds like a WD- could have been switched if your tractor is a WD45. Does the engine have a removeable cover on the right side? Then it's a WD. WD has a straight shift lever, not curved. The lower end of the shifter should be a tapered rectangle- not a ball. They can be welded up and ground off to match the shifter forks.
