Re: Allis G Stuck..Please help
Plant Doctor
12-31-2002 05:14:18
Mark: I can't speak with a lot of personal knowledge on stuck "G's", but several years back I bought a used "G" motor that did the same thing as yours. I removed the plugs and put some penetrating oil in each cylinder. Then using a big socket on the nut that is also used to hand crank the motor, I got the crankshaft to turn slightly back and forward. I kept working it very easily not forcing it and it finally went all the way around. Then I used the starter to turn it and after it freed up nicely I put the plugs back in and it started. Bad news is, I ended up overhauling it, it used the same amount of motor oil as it did gas. If you do this, be careful not to unscrew that crank nut when turning the motor backward. Good Luck!
