Re: Help changing fluids
Dave Grubb
12-26-2002 07:58:59
The drain plug in the bottom of the hydraulic reservoir is/should be a magnetic plug that should be cleaned before reinstalling. There is a drain plug on the bottom of the transmission case. There is a ddrain plug in the bottom of the PTO case. There is a drain plug in the bottom of the rear end case. There is a drain plug in the bottom of the control valve on the aft end of the hydraulic pump. You have to remove the pans on the bottom of the final drives to drain those. The hydraulics get refilled through the dip stick hole with any good brand of universal hydraulic/wet brakes system fluid, better choice than engine oil in my opinion. There are two square head pipe plugs on the same side of the tractor as the hydraulics reservoir dip stick. The first one back from the hydraulics is the transmission, fill to overflow with 85W140 gear lube. The next one back is the rear end, fill to overflow with 85W140 gear lube. The final drives are filled to overflow with 85W140 gear lube through each pipe plug on the inside face and a few inches above the pan gasket surface of the final drives. I use 5W30 oil in my engine during the winter and 30W in the summer.
