Re: Allis Chalmers 6-12 conversion, Starter???
Doug in OR
12-22-2002 20:38:42
The six volt starter will work just fine. You do need to be a bit careful, though. Continuous cranking will overheat the starter. I believe the recommendation is something like 20 seconds of cranking, followed by a one minute rest. If your engine is properly tuned, long cranking times shouldn't be a problem.
It is possible that someone overheated that starter. It is also possible that the starter may need to be rebuilt because it is worn.
Steve in N.J.
12-22-2002 20:58:27
 Re: Re: Allis Chalmers 6-12 conversion, Starter??? in reply to Doug in OR, 12-22-2002 20:38:42
Ya hit that one right on the head Doug! Don, the starter may have worn bushings in it and she's dragging a bit from spinning faster. Are you hearing any noise while she spins?. Steve B.
ACmaninNC
12-23-2002 14:59:44
 Re: Re: Re: Allis Chalmers 6-12 conversion, Starter??? in reply to Steve in N.J., 12-22-2002 20:58:27
Most of the time a 12 volt system can handle the same starter. It adds electricity which makes more heat. Check if the starter is HOT if it is you have a short in it and it will need a rebuild job. Bad cables sometimes short out.
AC
Don
12-22-2002 21:36:23
It is spinning very slowly and somnetimes it won't spin at all and just acts like a dead short. I live in Oregon, where is a good place to get it rebuilt, or the parts and I can do it myself. Well maybe, I used to rebuild the old chevy starters. Unless there is a short in it.
Steve in N.J.
12-23-2002 03:30:10
 Re: Re: Re: Re: Allis Chalmers 6-12 conversion, Starter??? in reply to Don, 12-22-2002 21:36:23
Don,
I rebuild starters and alternators, but I'm sure there's got to be someone in your neck of the woods that does rebuilding. Check in your local auto parts stores in your town ask them who is a replicable rebuilder locally. They should be able to help ya. Make sure your battery is up to doing the job with a load on it. Also, make sure you have good clean connections on both ends of the battery cables. A lousy connection whether it be on the hot side or the ground side will make a starter spin slowly. Inspect the wiring for any breaks or worn through spots too. Hope this helps... Steve
Gene (Pa)
12-23-2002 13:42:45
 Re: Re: Re: Re: Re: Allis Chalmers 6-12 conversion, Starter??? in reply to Steve in N.J., 12-23-2002 03:30:10
I have seen several posts on allischalmers forum about starters (grounding etc.) you might be interested in.
Steve in N.J.
12-23-2002 03:28:06
Don,
Doug in OR
12-22-2002 21:58:13
Look in the yellow pages. There should be something under "Automotive". They would note that they do electrical service too. This might include starter and generator rebuilding.
