Company Logo (800) 853-2651 Shop Now
Re: Removing reservoir on wd45
Tom
12-22-2002 17:20:19
The hydraulic resevoir is infront of the transmission and has a seperate drain plug. If you didn't know this you could confuse it with a part of the transmission. The pto or plate over the pto if there is no pto is the front drain for the transmission, next trans drain is under the shift lever part in a sheetmetal plate (difficult to get to), and the third one is under the rear end. If you are changing oils don't fortet the final drives. The hydraulic oil is checked with a small dipstick on the top left of the hydraulic resevoir near the clutch linkage. The serial no. is on the back of the rearend on the left side behind the left brake on the machined surface below the brke spring and adjusting screw.
Today's Featured Article - Identifying Tractor Smells - by Curtis Von Fange. We are continuing our series on learning to talk the language of our tractor. Since we can’t actually talk to our tractors, though some of the older sect of farmers might disagree, we use our five physical senses to observe and construe what our iron age friends are trying to tell us. We have already talked about some of the colors the unit might leave as clues to its well-being. Now we are going to use our noses to diagnose particular smells. ELECTRICAL SMELLS ... [Read Article]
Latest Ad: JD factory 3pt hitch fits 2 cyl 20 and 30 series tractor and 2 JD rear wts for late 2cyl and new gen Price 2000 for pkg calls only [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
