Re: 12 Volt Generator
Frank, Tx
12-20-2002 17:27:15
Mike, You have at least a couple of choices for your 12volt system. If you want to use a generator, you can get a 12v generator from most generator/alternator repair shops that will fit into your Allis factory mounting bracket. You will need a 12volt voltage regulator also. Another optiion is a 6v generator with a 12volt regulator. You will probably have to put a small pulley on the generator to get a satisfactory charge rate with the 6volt generator and 12v voltage regulator. Unless you want to try and keep your tractor looking "original" probably the best solution is a Delco Remey model 10 SI alternator, which has built in "voltage" regulation. Dewey on this board and Clooney on the John Deere board will gladly provide wiring diagrams for doing any of the above. You can probably find out all you need to know by doing a search of the archives for either of these boards.
LOL, Frank
karl
10-29-2003 18:11:21
 Re: Re: 12 Volt Generator in reply to Frank, Tx, 12-20-2002 17:27:15
did i read where you said you can use a 6 volt generator with a 12 volt system? if you have any information on this subject i would really like a respnose as i have a couple 6 volt generators as i changed mine over to 12 volt and i have asked many people if this is possible to do and no one knew. thanks you-karl
