Company Logo (800) 853-2651 Shop Now
Re: Little thing on generator
steve
12-19-2002 16:06:16
most alternators have internal voltage regulators. all generators have some fore of external voltage regulation. the old 6 volt systems have a small tin box on the generator that connects from the "A" terminal, to the amp meter. this is called a cutout relay and it disconnects the power line so the battery will not discharge when the motor is off. this "Box" is actually 1/3 of a normal voltage regulator. your light switch is the current regulator portion of the regulator. both of there will need to be installed in you have a 6 volt system. if you have a 12 volt generator, you might be able to install a normal voltage regulator and mount it away from all this clutter. You need to know if the generator is 6 or 12 volt, and positive or negative ground. I can help as can others, if you fill in the blanks.
Latest Ad: Looking for a carburetor for a John Deere h or b also a magneto [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
