Re: wd45 compression
TimC
12-19-2002 14:07:02
Moisture in distributor?
Don
12-19-2002 17:33:46
 Re: Re: wd45 compression in reply to TimC, 12-19-2002 14:07:02
OH, HOW TIMING CAN BE EVERYTHING IN LIFE!!!
Couldn't find the timing mark but decided to change it a little at a time and it is running much better. Timing mark should be on the flywheel. There is a small square opening on the side of the bell houring where the flywheel is visable but there is not mark on the flywheel.
Anyways, has a lot more power now and I will keep experimenting. If anyone knows where that timing mark is Let me know.
Thanks again for all the help. You have all helped more than you know.
chuckster
01-10-2003 07:19:17
 Re: Re: Re: wd45 compression in reply to Don, 12-19-2002 17:33:46
check under the bellhousing ther should be another inspection plate
