Re: wd45 compression
Willie
12-19-2002 06:28:09
Don
A quick& dirty way to check the governor- tie a string to the linkage going into the carb. Pull the string gently while driving. If it responds the gov is giving trouble, if no change, the gov is okay. According to my book, point gap is .010 on mag, .020 on bat ign. Backfire thru carb USUALLY means lean mixture.
Side note- bought a WD last summer, ran smooth but no power. Turns out that roll-pin thru gear&gov shaft was part way out, hanging up gov weights, wouldn't let it operate. Spent an hour removing gov assembly & gentle tap with BFH fixed it.
HTH
Willie
