Re: wd45 compression
punchie
12-18-2002 13:52:26
HI Don
I would say it is the timing, or points. Double check both. Some of the wd etc. are not going to run if cold, someone else has talk on that too. Bad gas ? Governer trouble may not idle or pull right , when you would give it gas it would act funny. Good Luck!!
Punchie
Don
12-18-2002 22:55:37
 Re: Re: wd45 compression in reply to punchie, 12-18-2002 13:52:26
In this forum the tune up specs say the points should be set at 20 but inside the magnito it says 30 so that is what I set them at. Should I change them to 20?
Steve in N.J.
12-19-2002 15:25:30
 Re: Re: Re: wd45 compression in reply to Don, 12-18-2002 22:55:37
My books all say .020 for mag. That's what I've been setting them at when I rebuild em' for my customers...
Steve B.
