Re: wd45 compression
Steve in N.J.
12-18-2002 06:12:56
Don,
Is it backfiring in the exhaust or intake side?
Recheck your mag timing from the rebuild. Couple other things to check that would cause a backfire and no power:
Fuel delivery- (lean) carb or fuel flow problem
Valve train- tight/loose valve, or chunk of carbon under a valve, worn cam. One new Champion spark plug out of four if used. Someone else I'm sure can help ya with the governor. Hope those suggestions can give you something to go on.. Steve B.
