Re: ANTIFREEZE LEAK ON A MOD. (G)
Plant Doctor
12-16-2002 15:39:10
Dave: Those G's had a habit of leaking around the head bolts. The head bolts go all the way through to the water jacket and sometimes with temperature changes they would leak between the head and the head of the bolts. That's if your lucky, sometimes they leak past the head gasket. If you watch it closely you will find the bolt causing the problem. Either tighten it slighty or remove it and use a sealing compound on the threads and re-tighten to specs.
