Company Logo (800) 853-2651 Shop Now
Re: Tractor Advice Needed
CA, WD45, or D series
Ron
12-12-2002 05:30:35
What ever you use, have a PTO slip-clutch on the PTO shaft, and make sure you adjust it so it CAN slip, if it has to..!!! That will take a lot of the shock out of the drive line.... The older WD PTO is not quite as strong as the WD-45 PTO....the lower gear box was strengthened in the 45...but, I have broken mine once, in the WD-45...The top "Ears" break off that hold the idler to the top of the lower gearbox.. The 45 gearbox would fit the WD also...would be a good up-grade...!! But..it HAD seen enough service, for 4 tractors.!! Many 1,000's of hours of custom combining and baleing...also Bush Hogging.... If I bought a WD-45.I would take the lower gearbox off, and have it Magnafluxed...just for peace of mind..!!
Today's Featured Article - Identifying Tractor Smells - by Curtis Von Fange. We are continuing our series on learning to talk the language of our tractor. Since we can’t actually talk to our tractors, though some of the older sect of farmers might disagree, we use our five physical senses to observe and construe what our iron age friends are trying to tell us. We have already talked about some of the colors the unit might leave as clues to its well-being. Now we are going to use our noses to diagnose particular smells. ELECTRICAL SMELLS ... [Read Article]
Latest Ad: JD factory 3pt hitch fits 2 cyl 20 and 30 series tractor and 2 JD rear wts for late 2cyl and new gen Price 2000 for pkg calls only [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
